BT.com
Wishlist
Epson EB-475WI 2600 ANSI lumens WXGA Interactive Projector
Free delivery
Delivery
Standard Due date unavailable
Large fully interactive projections
With Epson's EB-475Wi, you can easily achieve a large projected image size of up to 100 inches/245cm that's fully interactive, right up to the corners. Thanks to the ultra-short-throw design, you can project a 46-inch/116.8cm image from just 27cm away, and annotating can easily be done without casting distracting shadows.
You're in control
This is Epson's first interactive projector to feature two digital pens that allow teachers and students to work together at the same time. These pens are more responsive and easier to use than previous models, thanks to the new 'hover' function that accurately detects the position of the pen when not in contact with the projection surface. The automatic calibration and the driver-less installation means that set-up is extremely fast and easy.
Everything you need
This package includes the projector, wall-mount and two digital pens, and doesn't need a separate screen. It can be mounted in four different ways to maximise learning opportunities: on your wall, on the ceiling or even to the underneath or side of a desk. Mounting to a desk allows groups to work together on documents or multimedia files.
Easy installation and control
Epson has designed this projector to be quick to set up and use. You simply turn on and plug in - there's no warm-up time involved. The image is calibrated automatically and there's also a 16W built-in speaker. You don't even need to switch on your PC as the built-in 'instant annotation' tool allows you to draw on any projected background or video.
Low costs
With the Epson EB-475Wi, running costs are kept low with the long lamp life of 4,000 hours or four years, in eco mode, and the 5,000-hour filter life.
High-quality images
Epson's 3LCD technology ensures high-quality images with its equally high White and Colour Light Output for vivid, natural colours and deep blacks, even in daylight. The HDMI input also means high-definition content can be displayed with maximum clarity.
Epson EB-475Wi LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
2600 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
190 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Video Output
RGB
Speakers
Speaker(s) - integrated
275 Watt
36.7 cm x 37.5 cm x 14.3 cm
5.4 kg
3 years warranty
LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
2600 lumens
Contrast Ratio
3000:1
Image Size
142 cm - 254 cm
Throw Ratio
0.27:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels (1,280 x 800) x 3
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-5/ +5
Horizontal Keystone Correction
-5/ +5
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
1080p
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x component video input , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
Wall mounting kit, 2 digital presentation pens, wireless remote control
1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
275 Watt
Power Consumption Operational (Standby)
0.27 Watt
Software Included
Drivers & Utilities
36.7 cm
37.5 cm
14.3 cm
5.4 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
Sound Emission
35 dBA
28 dBA
Scroll to top
