BT.com
Wishlist
Emulex OneConnect™ Dual-Port 10Gb/s Ethernet Network Adapter
Delivery
Standard Due date unavailable
Emulex OneConnect OCe11102-NX dual-port 10Gb/s Ethernet network adapters with copper interconnects feature stateless TCP/IP and TCP Chimney offload for maximum performance using minimum CPU resources. Based on the third-generation BE3 controller, the OCe11102-NX reduces power costs with leading scalability per watt. The OCe11102-NX optimizes server virtualization with support for VMware NetQueue, multiple NIC functions and support for Single Root I/O Virtualization (SR-IOV).
Emulex OneConnect OCE11102-NX - network adapter - 2 ports
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
16.8 cm x 6.9 cm
Ports Qty
2 ports
Cabling Type
Ethernet 10GBase-CR
10 GigE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux Server
Microsoft Certification
Compatible with Windows 7
Synology RackStation RS3412RPxs, RS3412xs
Network adapter - 2 ports
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Wired
Cabling Type
Ethernet 10GBase-CR
10 GigE
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
Flow control, VLAN support, IPv6 support, Quality of Service (QoS), IPv4 support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS)
2 x 10GBase-CR
Compatible Slots
1 x PCI Express 2.0 x8
C-Tick, CISPR 22 Class A, VCCI Class A ITE, EN55024, EN55022 Class A, EMC, ICES-003 Class A, RoHS, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, FCC Part 15 A, EN 60825-1, BSMI Class A, KCC Class A
16.8 cm
6.9 cm
55 °C
5 - 95% (non-condensing)
Scroll to top
