BT.com
Wishlist
ELO 3243L Openframe 32" 1920x1080 6.5ms VGA DVI Touchscreen LED Large Format Display
Delivery
Standard Due date unavailable
The Elo Touch Solutions 3243L 32-inch Full HD open-frame touch monitor provides smooth dual-touch performance with IntelliTouch Plus surface acoustic wave technology. The 3243L touch monitor is 2.3 inches in total thickness and less than 1-inch in border width. The sleek mechanical design enables thinner and smaller kiosk design for various applications like retail, hotels, gaming, transportation and other commercial uses. The 3243L features a unique, injection-molded bezel with a virtually invisible water-resistant seal, making it a good choice for the rigors of public use. Narrow borders, multiple mounting options, and a USB touch interface add to the versatility of the 3243L.
Elo 3243L - LED monitor - 32"
LED-backlit LCD monitor - 32" - touchscreen
Touch-screen
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
6.5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
73.54 cm x 5.8 cm x 44.3 cm
12.3 kg
Worldwide
UL, VCCI, C-Tick, BSMI, GOST, cUL, NOM, UL 60950, CB, CCC, IC, FCC, RoHS, WEEE, S Mark, KC
3 years warranty
Display Type
Diagonal Size
32"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
6.5 ms
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, aspect control
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
IntelliTouch Plus Surface Acoustic Wave, OSD lock
73.54 cm x 5.8 cm x 44.3 cm - with stand
12.3 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Intellitouch SAW
VGA , DVI-D , USB
Mechanical
Flat Panel Mount Interface
400 x 200 mm
IntelliTouch Surface Wave
Mounting Kit
Included
MTBF
50,000 hour(s)
Worldwide
Power Supply
Internal
55 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 3 years
20 - 80% (non-condensing)
Scroll to top
