BT.com
Wishlist
Eizo Generic Eizo LED Monitor 2560 x 1440 16:9 Black Bezel 2 x 1 built in
Eizo Generic Eizo LED Monitor 2560...
£575.29
£575.29
Add to wishlist
Delivery
Standard Due date unavailable
The ergonomic and eco features of this 27" monitor make office work more comfortable while keeping power usage in check.
A thin bezel design saves space on the desktop and minimizes eye movement between screens in a multi-monitor environment.
EIZO FlexScan EV2736W - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
64 cm x 24.55 cm x 39.95 cm
10 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, TUV GS, C-Tick, DVI DMPM, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, WEEE, GOST-R, cTUVus, EPA, TCO Displays 6.0, VCCI Class B
5 years warranty
Display Type
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
59 - 61 Hz
Horizontal Refresh Rate
31 - 89 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, saturation, gamma correction, colour temperature, phase, smoothing, clock, hue
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Swedish, Spanish, Japanese
sRGB colour management, HDCP, BrightRegulator, Fine Contrast, Overdrive technology, Auto EcoView, EcoView Sense
64 cm x 24.55 cm x 39.95 cm - with stand
10 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , DisplayPort , Audio line-in , Headphones , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
30
Swivel Angle
344
Rotation Angle
90
Height Adjustment
145 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable
Power Supply
Internal
67 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
ScreenManager Pro for LCD, EIZO ScreenSlicer
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.5 cm - height: 37.9 cm - weight: 7.3 kg , With stand - width: 64 cm - depth: 24.55 cm - height: 39.95 cm - weight: 10 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
