BT.com
Wishlist
Eizo FlexScan 21.3" 1600x1200 6ms VGA DVI DisplayPort IPS LED Monitor
Eizo FlexScan 21.3" 1600x1200 6ms...
£676.81
13 in stock
£676.81
Add to wishlist
Delivery
Standard 1-3 working days
With its IPS panel and 1600 x 1200, resolution, the FlexScan S2133 is ideal for businesses and control rooms that need to display a large volume of data as well as for CAD and other design work that require brilliant color display.
EIZO FlexScan S2133-BK - LED monitor - 21.3"
LED-backlit LCD monitor - 21.3"
USB 2.0 hub
Panel Type
IPS
Native Resolution
1600 x 1200
Pixel Pitch
0.27 mm
Brightness
420 cd/m²
Contrast Ratio
1500:1
Response Time
20 ms (rise+fall); 6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
46.5 cm x 20.9 cm x 45.3 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, C-Tick, DVI DMPM, TUV S, VESA DPMS, CB, ICES-003 Class B, CCC, TUV Ergo, RoHS, ISO 9241-307, WEEE, GOST-R, cTUVus, EPA, TCO Displays 6.0, VCCI Class B, China RoHS
5 years warranty
Display Type
Diagonal Size
21.3"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Native Resolution
1600 x 1200
Pixel Pitch
0.27 mm
Brightness
420 cd/m²
Contrast Ratio
1500:1
Colour Support
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
24 - 80 kHz
Video Bandwidth
162 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, saturation, gamma correction, colour temperature, phase, clock, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Swedish, Spanish, Japanese
Fine Contrast, Overdrive technology, Auto EcoView, On-screen Digital Controls, EcoView Optimizer 2, EcoView Index
46.5 cm x 20.9 cm x 45.3 cm - with stand
8.6 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
40
Swivel Angle
70
Rotation Angle
90
Height Adjustment
82 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable - VGA to VGA , 1 x USB cable
Power Supply
Internal
45 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities, EIZO ScreenSlicer, ScreenManager Pro for DDC
Dimensions & Weight Details
With stand - width: 46.5 cm - depth: 20.9 cm - height: 45.3 cm - weight: 8.6 kg , Without stand - width: 46.5 cm - depth: 6.4 cm - height: 36.1 cm - weight: 5.6 kg
ENERGY STAR Certified
Limited warranty - replacement - 5 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
