BT.com
Wishlist
Eizo EV2455-BK 24" 1920x1200 5ms VGA DVI HDMI IPS LED Monitor
Eizo EV2455-BK 24" 1920x1200 5ms...
£372.25
£372.25
Add to wishlist
Delivery
Standard 1-3 working days
The monitor features a "fusion" design that combines EIZO's own EcoView technologies for reduced power consumption and improved visual ergonomics inside an extremely compact cabinet.
EIZO FlexScan EV2455-BK - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
53.08 cm x 23.3 cm x 48.82 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, RoHS, WEEE, PSE Mark, GOST-R, cTUVus, J-MOSS, TCO Displays 6.0, VCCI Class B, China RoHS, RCM
5 years warranty
Display Type
Energy Class
Class A+
22 kWh
15 W
Diagonal Size
24.1"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
31 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
sRGB colour management, HDCP, BrightRegulator, Auto EcoView, EcoView Sense
53.08 cm x 23.3 cm x 48.82 cm - with stand
6.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
344
Rotation Angle
90
Height Adjustment
131 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable
Power Supply
Internal
49 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.08 cm - depth: 23.3 cm - height: 48.82 cm - weight: 6.5 kg , Without stand - width: 53.08 cm - depth: 4.79 cm - height: 34.72 cm - weight: 4.1 kg
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
