BT.com
Wishlist
Edimax Wireless-N 150Mbps Mini USB Adapter
Incredible high-speed wireless network access
Delivery
Standard Due date unavailable
EW-7711UTn is a mini-size wireless USB adapter which provides a simple and easy way to add or upgrade wireless connectivity to your desktop or notebook computer. This nLITE mini-size USB adapter supports higher data rate up to 150Mpbs when connecting with wireless 802.11n device. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access.
Compatible with wireless 802.11n devices with data rate up to 150Mbps
EW-7711UTn complies with wireless IEEE802.11b/g standards. With built-in with the latest wireless technology, EW-7711UTn can increase the coverage 3 times more and reduce "dead spots" within the wireless range. The transmission data rate when connecting with wireless 802.11n devices is up to 150Mbps, which makes signal travel farther and maintain wireless connections much reliable than standard wireless IEEE802.11b/g network.
Supports WPS-compatible (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS-compatible configuration and hardware WPS push button. When both ends of the wireless connection use wireless solution with WPS, it will automatically configure the wireless network with robust WPA data encryption and authentication.
Supports multi-language EZmax setup wizard
The included 16 languages EZmax setup wizard and friendly UI will walk you through configuring EW-7711UTn to your wireless network.
Portable and compact design
The compact design of EW-7711UTn is convenient to carry for all mobile users.
Hi-Speed USB
Compatibility
PC
Manufacturer
Edimax Technology
Wired / Wireless
Wireless
Network adapter
Plug-in card
Protocol
IEEE 802.11n
IEEE 802.11b
Hi-Speed USB
IEEE 802.11g
Product Line
Edimax
Speed
150
Model
EW-7711UTn
Standards
USB 2.0
IEEE 802.11n
IEEE 802.11b
IEEE 802.11g
Resources
The following resources are available for the Edimax Wireless-N 150Mbps Mini USB Adapter
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Little Gadget
Reviewed by A Caplen on 17/11/2010
I have just bought this little wireless adapter and plugged it into my desktop computer which does not have a wireless card as it is somewhat older than my laptop, but still useful, adding this little dongle was a great idea and I have to say it does a great job and it was so cheap, I ran the disc again because the first time it was not good but then it started working and just like they say in the discription it is a powerful little gadget
5* low standard
Reviewed by Anonymous on 16/10/2010
I bought the item above and was disapointed with its performance. The output a mere 65Mbps an increase of 11Mbps,hardly worth the bother and certainley not worth the cost
5* Disappointing
Reviewed by Dennis Parker on 14/10/2010
I was looking for something to improve the signal strength and speed in one room of the house where it is very low and often not at all. The description of this product seemed to be ideal. Once installed, I was left with no signal where I was hoping to improve and considerably reduced signal strength in other parts of the house where I normally have excellent strength. As a result I have returned to my original set-up and put this product away, in short a waste of time.
5* Edimax Wireless Adapter
Reviewed by Mike George on 28/07/2010
I live in an old house with very thick walls, and consequently a low wireless signal in many rooms. Decided to try this as a cheap fix, and it really is good. Highly recommended!
4* Simple and effective communications
Reviewed by Richard on 10/07/2009
Good solid product. Note this is not a true N-draft device (max. 600Mbps) but has a maximum speed of 150Mbps! However, given the 802.11n specification has yet to be finalised (decision due December 2009), this is a good product to use on existing and migrating networks.
The device is very small (1/2 length) and comes with a USB cap which unfortunately cannot be clipped to it once its inserted, thus can be easily lost. This size makes it particularly useful for laptops/netbooks.
The device requires its installation CD to install drivers which work for both 32bit and 64bit editions of Windows Vista. It is compatible with Windows Zero Configuration - by far the easiest way of connecting to networks.
I gave it a 4/5 rating because of: it's speed limitations, the removable cap and lack of native Vista driver support.
1* Disapponting
Reviewed by Dennis on 14/10/2010
Just writing to correct my previous rating (don't know where that came from) - Overall product rating 0 not the 5 listed. Don't be tempted to buy this product.
1* Useless
Reviewed by Anonymous on 25/10/2010
No problems installing it but the signal is too weak to connect
to internet even with the computer standing next to the router. A complete waste of time
1* Disappointing
Reviewed by Tracey on 20/08/2010
Bought two of these for my children's xp computers. One refused to connect to the BT hub no matter what I tried (rebooting the hub, changing channel etc) the other connected fine but it ran at 6 mbps at best. Put the old Linksys wireless g adapters back on and both computers work consistently at 54 mbps.
Scroll to top
