BT.com
Wishlist
Edimax Wireless-N (802.11n) Range Extender
Delivery
Standard Due date unavailable
PC Pro logo
Wireless 802.11n Access Point
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes.
Universal Repeater Mode
The Universal Repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools.
Robust Wireless Security with WPA and WPA2
Except for the basic security control by ESSID and 64/128 bit key length WEP encryption, this access point also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hidden ESSID. It provides a total solution for you to build up a secure wireless network environment that can prevent from all kinds of hacker intrusion.
Web Configuration
You can configure this access point through the friendly Web user interface with a browser.
Edimax EW-7416APn - radio access point
Radio access point
External
RAM
16 MB
Flash Memory
4 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Frequency Band
2.4 GHz
Microsoft Windows 95/98, Microsoft Windows 2000 / ME / XP/ Vista
12.7 cm x 9.6 cm x 3 cm
Radio access point
12.7 cm
9.6 cm
3 cm
Processor / Memory / Storage
RAM
16 MB SDRAM
Flash Memory
4 MB
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
DHCP support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft)
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
3 dBi
1 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
10 °C
10 - 90%
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Low cost, easy to use, flexible and compact
Reviewed by RK on 23/04/2009
As an IT professional managing large scale commercial wireless projects with the latest technology, I see my fair share of wireless LAN equipment. I bought these devices for use in my home as they appeared to be very flexible in terms on configuration and very low cost for a seemingly high specification. I was thankfully correct, they are superb little devices that are in fact multi-role. Not only are they extenders, but access points, bridges and more. Easy to set up,I had one as a main access point and another as an extender set up, fully secured within 15 minutes. Not only this but the footprint is literally half that of my existing Linksys WAP54G access points - Tiny...! Highly recommended.
5* Excellent
Reviewed by Dan on 08/10/2010
Up and running in less than 5 mins. I am using it as a wireless extender and as such it is great.
5* Superb
Reviewed by DT on 24/04/2009
Couldn't agree more with the other reviews. Great little device, achieves all that it says and not many products give you that!
"Not only are they extenders, but access points, bridges and more."
5* Edimax Wireless-N (802.11n) Range Extender
Reviewed by Tim Durham on 09/01/2013
I have been using one of these for over a year and decided to buy another one to connect my Sky box to my wireless network. The price is good for what it does and the old one has work very well so far. I order it from BT and it turned up on time. The instructions said "connect it to your network and run the setup wizard". I don't use a standard domestic IP in my house and that means I usually have to change network settings any new things I connect to. However, the wizard saw both the old and the new extenders. I select the new one and it asked if I want to change its IP address(big tick in the box from me). It gave me three options for how I wanted to use it. I wanted number 2 (next big tick). It then showed me a list of wireless networks. I selected mine and put in the pass key. So, from out of the box to up and running took about 55 seconds - the longest bit was finding the passowrd in the manual. And it worked with Sky without any issues. I heartily recommend this product.
5* Effective range extender
Reviewed by Anonymous on 24/03/2009
Purchased as a range extender for BT HomeHub2. Straightforward setup to Universal Repeater Mode. Works well. No complaints.
5* Re-boot, maybe
Reviewed by Ian Leonard on 08/08/2009
Followed the instructions to the letter on using as an N extender (it can do more) and pinged as expected when connected by wire, got a network conflict when wireless, got late & went to bed, next day booted up & it worked beautifully. Now have 90% signal in living room instead of 15% from the Linksys router and am driving my Squeezebox wirelessly. I do heartily recommend this product. I also have an Edimax N pcmcia card I think it's all good stuff, & good value.
5* Seems like a great wee box...
Reviewed by Fraser on 04/12/2009
Arrived this afternoon and took me about 45mins to set up and get working. Instructions are a wee bit difficult to understand sometimes (well, to a complete novice like me) which is why it took so long. Using it as a range extender for my BTHomeHub2 - working great so far. Definately recommend.
5* Got there in the end
Reviewed by Paul on 17/02/2010
Bought as an extender. Tried following the full manual (Quick set up guide is poor). Had problems accessing to the system maintenance page for the new box.
An email to Edimax support got me pointed to instalation document on their uk website mentioned below. Followed that and, bar there being a slight error regarding the IP address to use, it was set up in a few minutes. (Find out what your routers address is before you start. It may not be as quoted in the instructions and you'll need to set the extender as a sub of that.)Signal boosted by about 50% in the farthest reaches of the house now. And it's tiny compared to some i looked at.
5* Fantastic
Reviewed by jd jones on 14/10/2010
Quick and easy to set up, had so many problems with loss of signal from my Bthomehub 2, this is perfect as a wireless extender .
5* Excellent Solution to Networking Problem
Reviewed by Giles on 19/05/2011
I've used 5 of these to network a 500 seat Victorian Theatre. We needed to network our rehearsal room, which is 3 floors down and complete opposite to the building from the office with the internet connection. The building is over 150 years old, and used to be an Iron Foundry, so there are very thick walls and plenty of iron in the building, however these did an excellent job. It took me about 2 hours to setup all of them, and we now have strong WiFi signal throughout the building (even though we didn't need this!)
The distance was just too far for cat5e cable, and with such thick stone and brick walls, even tacking cable down would have been a nightmare, let along running it through walls and public areas. These are an elegant solution, and with WiFi access on a commercial scale in this HUGE building at less than £250, we couldn't be more pleased.
Scroll to top
