BT.com
Wishlist
Edimax Wireless HD Day/Night Pan/Tilt Cloud Camera with Temperature Sensor
Edimax Wireless HD Day/Night...
£100.41
£100.41
Add to wishlist
Delivery
Standard 1-3 working days
The Edimax IC-7113W 720p HD Pan and Tilt Wi-Fi network camera is a versatile monitoring device ideal for monitoring your home, shop or factory during the daytime and at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop.
The IC-7113W features a motion & sound detection system, two-way audio, built-in microphone & speaker, built-in selectable lullabies, temperature & humidity sensor and a microSD/SDHC card slot. Motion and sound-triggered recording ensure that you capture any unusual activity and the wireless user interface allows for easy installation and monitoring.
Smart HD Wi-Fi Pan/Tilt Network Camera with Temperature & Humidity Sensor, Day & Night
  • Plug-n-View for 24/7 Remote Monitoring with free EdiView II app on iPhone, iPad or Android or EdiView software for computers
  • Night Vision with infrared LEDs and auto light sensor
  • Motorized Pan & Tilt for wider viewing angle
  • Multi-Area Motion & Sound Detection triggers recording and sends to email or ftp
  • Push Notifications with Video Alerts when motion or sound is detected
  • Two-Way Audio with built-in microphone and speaker for easy on-site communication and alerts
  • Acoustic Echo Cancellation (AEC) ensures crisp and clear sound quality during two-way audio communications
  • Built-in Lullaby can be played through the network camera to sooth your child to sleep
  • Temperature & Humidity Detection with Push Notification Alerts when above or below preset levels
  • Wireless & Ethernet Connection for flexible placement, and compatible with IEEE 802.11b/g/n products
  • Easy Setup & WPS Support
Edimax IC-7113W - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
11.2 cm x 12.8 cm x 11.6 cm
251 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate
30 frames per second
Optical Sensor Type
CMOS
Minimum Illumination
1 lux
Focal Length Control
Fixed focal
Lens Iris
F/2.0
Panning Range (degree)
-355 to +355
Tilting Range (degree)
-120 to +120
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 12 V
E-mail alerts, Motion Detection Technology, light sensor, infrared cut filter, Wi-Fi Protected Setup (WPS), temperature sensor, Plug-n-View, notification picture to FTP, humidity sensor, reset button, Audio Detection
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
11.2 cm
12.8 cm
11.6 cm
251 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
1 lux
Infrared LEDs
8
Infrared Distance
4.6 m
Video Capture
1280 x 720 @ 30 fps , 640 x 360 @ 30 fps , 320 x 176 @ 30 fps
RAM
128 MB
Flash Memory
8 MB
Image Sensor
CMOS
Lens Construction
Fixed focal
Lens Iris
F/2.0
Panning
Range (degree)
-355 to +355
Titling
Range (degree)
-120 to +120
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE, SNTP
Supported Memory Cards
microSD Card, microSDHC Card
Mounting kit
1 x network cable - external
FCC, RoHS
Power Requirements
DC 12 V
Power adapter - external
Software Included
Drivers & Utilities
Relative Humidity (operating)
Scroll to top
