BT.com
Wishlist
Edimax Wireless Full HD Fisheye Cloud Camera
Edimax Wireless Full HD Fisheye...
£107.56
44 in stock
£107.56
Add to wishlist
Delivery
Standard 1-3 working days
The Edimax IC-5150W fisheye network camera gives you wider, 180-degree panoramic views for more efficient security and monitoring in your home, shop or factory without the blind spots associated with traditional standard lens network cameras. And with Edimax Plug-n-View technology, there’s no complicated setup so you can connect the camera to the cloud without any hassle and monitor remotely from a smartphone, tablet or laptop. With a built-in microphone, sound and motion detection system and microSD / SDHC card slot, the camera is well equipped to protect your property as well as fully customizable. Motion detection can be configured according to user-defined areas, and together with sound detection and sound-triggered recording offers a powerful security system that’s always on alert to capture anything suspicious. And for installation and monitoring, the intuitive Wi-Fi user interface makes everything a breeze.
Edimax IC-5150W - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability, built-in microphone
Camera Mount Type
Wall mount
4.5 cm x 3 cm x 9.5 cm
75 g
Wired, wireless
Camera
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Optical Sensor Type
CMOS 2 MP
Focal Length Control
Fixed focal
Focus Adjustment
Manual
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 12 V
E-mail alerts, Wide Dynamic Range (WDR), Motion Detection Technology, Wi-Fi Protected Setup (WPS), ePTZ, Push Notification, reset button, sound sensor, cloud recording
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wall mount
Wired, wireless
4.5 cm
3 cm
9.5 cm
75 g
Camera
Colour - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Video Capture
1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
RAM
64 MB
Flash Memory
8 MB
Image Sensor
2 MP CMOS
Lens Construction
Fixed focal
Lens Iris
F/2.0
Focus Adjustment
Manual
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
142
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE, SNTP
Ports
LAN - RJ-45 , USB 2.0 - 4 pin USB Type A
Supported Memory Cards
microSD Card, microSDHC Card
Wall mount kit
1 x network cable - external
FCC
Power Requirements
DC 12 V - 1 A
Power adapter - external
Software Included
EdiView Finder
Relative Humidity (operating)
Scroll to top
