BT.com
Wishlist
Edimax Wi-Fi 300N USB Adapter
£12.72
More than 50 in stock
£12.72
Add to wishlist
Delivery
Standard 3-5 working days
Enjoying high-speed wireless network access is as simple as plugging the Edimax EW-7612UAn V2 into your computer's USB port. This high-gain wireless USB adapter is a quick and easy way to add high-speed wireless connectivity to your desktop, laptop, or notebook computer. You can enjoy data rates of up to 300 Mbps when the Edimax EW-7612UAn V2 is connected to wireless 802.11n standard devices.
The Edimax EW-7612UAn V2 allows for increased wireless coverage and higher data transmission rates. The latest wireless technology is built into this device to broaden its wireless coverage by 5 times and to reduce dead spots within the wireless range. The EW-7612UAn V2 complies with wireless IEEE 802.11 b/g/n standards and can reach data transmission rates of up to 300 Mbps when connected to wireless 802.11n devices. It also extends its wireless signal distance, and provides more reliable wireless connections than standard IEEE 802.11 b/g wireless networks.
The EW-7612UAn V2 has a built-in 3 dBi high-gain antenna, which enables it to achieve better signal quality compared to common USB adapters. The included hardwire USB cable also allows users to easily adjust the USB adapter's angle and placement for better wireless performance. The EW-7612UAn V2 has adopted a clever protocol for smarter management of power usage. This wireless USB adapter smartly adjusts its power output according to transmission distance and CPU offload. It drastically reduces power consumption when the connection is idle. Designed with green WLAN technology, the EW-7612UAn V2's power consumption can be reduced an average of 20% to 50%.
Edimax EW-7612UAN V2 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 1.5 cm x 15.5 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, USB 2.0, IEEE 802.11n
Microsoft Windows Vista / XP / 7
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Access Point operational mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
Gain Level
3 dBi
1 x aerial
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Software Included
EZmax Setup Wizard
1.5 cm
1.5 cm
15.5 cm
0 - 90% (non-condensing)
Scroll to top
