Click to visit BT.com
BT.com
Wishlist
Edimax Wi-Fi 150Mbps Mini USB Adapter
Quicklinx: 71JHWS00
Mfr#: EW-7811UN
Wired / Wireless: Wireless
Protocol: IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
Express delivery Order within the next 5 hours for delivery tomorrow
Hurry, only 1 left in stock!
£8.28
EW-7811Un is a nano USB wireless adapter that supports maximum range and speed. Despite the size, this tiny USB adapter supports higher data rate of up to 150Mbps when connecting with wireless 802.11n device which is 3 times faster than your normally 11g connection. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access. This is for sure a trendy piece of upgrade you can make to your wireless network.
Edimax EW-7811Un - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 1.9 cm x 0.7 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link activity, link OK
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green WLAN
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
Software Included
Drivers & Utilities, EZmax Setup Wizard
Additional Requirements
USB port (compatible with 2.0 specification)
1.5 cm
1.9 cm
0.7 cm
10 - 90%
Edimax Wi-Fi 150Mbps Mini USB Adapter Bundle deal on Edimax Wi-Fi 150Mbps Mini USB Adapter
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£11.90
saving £1.39
Resources
The following resources are available for the Edimax Wi-Fi 150Mbps Mini USB Adapter
Compatibility: PC
Brand: Edimax
Price Range Inc VAT: 0 - 50
