BT.com
Wishlist
Edimax Wi-Fi 150Mbps Mini USB Adapter
Edimax Wi-Fi 150Mbps Mini USB...
£7.02
22 in stock
£7.02
Add to wishlist
Delivery
Standard 3-5 working days
EW-7811Un is a nano USB wireless adapter that supports maximum range and speed. Despite the size, this tiny USB adapter supports higher data rate of up to 150Mbps when connecting with wireless 802.11n device which is 3 times faster than your normally 11g connection. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access. This is for sure a trendy piece of upgrade you can make to your wireless network.
Edimax EW-7811Un - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 1.9 cm x 0.7 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link activity, link OK
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green WLAN
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
Software Included
Drivers & Utilities, EZmax Setup Wizard
Additional Requirements
USB port (compatible with 2.0 specification)
1.5 cm
1.9 cm
0.7 cm
10 - 90%
Resources
The following resources are available for the Edimax Wi-Fi 150Mbps Mini USB Adapter
Scroll to top
