BT.com
Wishlist
Edimax USB 3.0 Network adapter
£17.70
More than 50 in stock
£17.70
Add to wishlist
Delivery
Standard 3-5 working days
With speeds up to 5 Gbps, USB 3.0 is fast becoming the standard in data-transfer technology for PCs and laptops. However, some computers only feature 10/100 Ethernet ports while Macbook Airs and often Ultrabooks don't feature Ethernet ports at all. Existing USB 2.0 Gigabit Ethernet adapters are limited by the USB 2.0 maximum data rate of 480 Mbps while the USB 3.0 adapter can reach speeds of 5 Gbps.
Edimax EU-4306 - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.8 cm x 1.36 cm x 7.32 cm
23.5 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Apple MacOS X 10.6, Linux Kernel 2.6.x, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Link activity, power
Flow control, wake on LAN (WOL), USB powered, Jumbo Frames support
1 x 1000Base-T - RJ-45
1 x SuperSpeed USB 3.0 - 9 pin USB Type A
FCC
2.8 cm
1.36 cm
7.32 cm
23.5 g
Scroll to top
