BT.com
Wishlist
Edimax USB 2.0 to 10/100Mbps Ethernet Ad
Edimax USB 2.0 to 10/100Mbps...
£8.35
26 in stock
£8.35
Add to wishlist
Delivery
Standard 3-5 working days
The Edimax EU-4208 USB 2.0 Fast Ethernet adapter is specifically designed to give Fast Ethernet connectivity to your ultrabook, or any computer without an Ethernet port. Simply plug this Fast Ethernet adapter into a USB 2.0 port on your ultrabook, and you can instantly gain access to a stable 10/100 Mbps Ethernet connection. The EU-4208 is also a quick and convenient way to add Ethernet connectivity to a desktop computer without the hassle of opening up the computer case. It is backward compatible with the USB 1.1 standard.
Edimax EU-4208 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
2.2 cm x 6.6 cm x 1.5 cm
25 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
RAM
20 KB
IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0
Apple MacOS X 10.x, Microsoft Windows 2000/XP/Vista/7
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Status Indicators
Link/activity
Auto-negotiation, USB powered
Processor / Memory
RAM
20 KB
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
FCC
600 mW
2.2 cm
6.6 cm
1.5 cm
25 g
70 °C
Scroll to top
