BT.com
Wishlist
Edimax Outdoor IP Camera with Night Vision
Delivery
Standard Due date unavailable
You can install the IP Camera easily on your home network and then access the IP Camera anywhere in the world with the video management utility. No need to set complicated DNS name or change the router's configuration. It's just plug & play.
Accesses IP camera easily without complicated settings
The IC-9000 is designed with the "user-friendly" concept. You can install the IP Camera easily on your home network and then access the IP Camera anywhere in the world with the video management utility. No need to set complicated DNS name or change the router's configuration. It's just a plug & play.
Views real-time video from IP camera on 3G mobile phone
With video management utility and 3GPP/ISMA support, the IC-9000 allows you to view the real-time video from the IC-9000 on the most 3G mobile phones* anywhere and anytime without fixed IP address setting.
Water proof & IR LEDs for all security and surveillance purposes
With the low light sensitive sensor and IR LEDs inside the IP66-rated water proof housing, the IC-9000 can satisfy all security and indoor/outdoor surveillance needs even in the dim environment or bad weather condition. Besides, with the automatic ICR (IR Cutter Remover), the infrared light is filtered out during the day time and is allowed to pass during the night time. This ensures the video color quality is excellent compared with other IP cameras.
MPEG-4 image compression
For outdoor surveillance and remote monitoring, the IC-9000 provides the best image quality in its class, and excellent performance. Its efficient bandwidth management offers 640x480 resolution, 30 fps frame rate, real MPEG4 image compression ability.
Supports motion detection and E-mail/FTP notification
The IC-9000 provides motion detection function and E-mail/FTP notification. You can easily setup this function and receive the notification with the snapshot images through email and/or ftp when motion events are detected.
Perfect video recording and NAS integration
The NAS storage function can easily turn standard NAS device ** to a NVR device and record the video from the IP cam in MPEG4 video codec . The schedule function provides full scheduling of email/ftp sending, motion detection and events recording. With the built-in Web server, the IC-9000 can also be managed from a standard web browser on a Windows computer
*Please check 3G mobile phone compatible list at www.edimax.co.uk
**Please check NAS compatible list at www.edimax.co.uk
Resources
The following resources are available for the Edimax Outdoor IP Camera with Night Vision
  • Documentation
Scroll to top
