BT.com
Wishlist
Edimax N300 Wireless ADSL Modem Router
Edimax N300 Wireless ADSL Modem...
£23.62
16 in stock
£23.62
Add to wishlist
Delivery
Standard 3-5 working days
300Mbps Wireless ADSL2/2+ Modem Router The Edimax AR-7286WnA/B is a high performance router that provides full ADSL2+ capability and superb reliability as a cost-effective networking solution for homes and small businesses.
Compatible with the wireless standard 802.11n, and with advanced MIMO technology, the AR-7286WnA/B provides up to six times better data transmission rates (up to 300Mbps) and five times better coverage than a standard 802.11g/b router.
All-in-One Device The AR-7286WnA/B is a wireless N router with a built-in ADSL2/ADSL2+ modem combining a high-performance router, modem, and a switch into a single device. Save desk space, the hassle of extra cords & cables and the cost of leasing a router from your DSL service provider.
Powerful and Wide Coverage Featuring two 5dBi high-gain antennas, the AR-7286WnA/B boosts your signal to ensure extended wireless networking range. Four-Networks-in-One The AR-7286WnA/B supports multiple SSIDs for up to four wireless networks.
Lightning Protection Protected from lightning strikes to help your device avoid the damage of a tough thunderstorm.
Supports TR-069 for Remote Management The AR-7286WnA/B also supports TR-069 which is a protocol to define a common method for CPE devices to communicate with a server.
Wi-Fi Protected Setup (WPS) Wi-Fi Protected Setup is a quick and convenient method of establishing wireless connections between compatible devices. Set up a wireless network in less than a minute with just a couple of clicks of a button or easily add new Wi-Fi devices to an existing network.
Easy Setup Wizard with Built-in ISP Selector Setup the ADSL modem router using the unique and convenient multi-language setup wizard provided on the included CD-ROM or available through a web browser. Select your language and follow a few simple steps to setup the router and configure the Internet connection, password, SSID and wireless security. Additionally, the setup wizard includes a built-in ISP selector to configure your ISP settings automatically.
Edimax AR-7286WnA - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, ARP
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP, Telnet, HTTP, TFTP, SSH
Firewall protection, NAT support, IGMP snooping, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IP address filtering, firmware upgradable, SNTP support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
13.5 cm x 2.8 cm x 11.8 cm
187 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
300 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, FCC
RAM
8 MB SDRAM
Flash Memory
2 MB
Status Indicators
Power, WLAN, LAN, ADSL, WPS
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.992.5 Annex A, ITU G.995.1
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
5 dBi
External power adapter
1 x network cable - 1 m , 2 x phone cable - 1.8 m
Software Included
EZmax Setup Wizard
13.5 cm
2.8 cm
11.8 cm
187 g
10 - 90% (non-condensing)
Scroll to top
