BT.com
Wishlist
Edimax N300 Mini Range Extender
£17.47
More than 50 in stock
£17.47
Add to wishlist
Delivery
Standard 3-5 working days
The Edimax EW-7438RPn Mini Wi-Fi Extender is a Wi-Fi extender with built-in power adapter in a compact design which can be plugged directly into an electrical outlet. The ES-7438RPn Mini comes with an intuitive iOS & Android smartphone companion app for controlling the Wi-Fi schedule and guest network. Convenient placement allows you to increase the signal coverage of your Wi-Fi network for better Wi-Fi quality. Featuring smart iQ Setup, installation is quick and easy and the EW-7438RPn Mini features 3-in-1 Wi-Fi extender, access point or wireless bridge operating modes. Just configure the mode you need for your network environment. Additionally, it complies with wireless 802.11b/g/n standards and provides data transmission rates of up to 300Mbps. With the Edimax EW-7438RPn Mini, you can enjoy high-speed wireless networking throughout your home without additional cabling.
Eliminate Wi-Fi Dead Zones & Double The Wi-Fi Coverage With Ease
Plug the extender directly into an electrical outlet and the Edimax EW-7438RPn Mini can easily extend Wi-Fi coverage to dead zones which your existing Wi-Fi signal can’t reach and increase the signal coverage of your Wi-Fi network for better Wi-Fi quality.
Smart 3-in-1 Extender, Access Point And Wireless Bridge
The EW-7438RPn Mini can work as Wi-Fi extender, access point or wireless bridge. Just configure the mode you need for your network environment using the smart iQ Setup wizard and enjoy surfing the web.
Smart App Control & Analytics
The extender works together with our free EdiRange smartphone app which displays your local Wi-Fi environment and provides easy-to-understand analytics. Plus you can manage the extender’s wireless network and functions such as scheduling and guest network.
Compact, Slim Wall Plug Design
Plugs directly into an existing electrical socket – no need for an additional power cable. Not only is the Edimax EW-7438RPn Mini slim and compact, it is designed with a built-in power adapter. This allows you to plug it directly into an electrical outlet, eliminating the need for an additional power cable. You can easily install it where your Wi-Fi signal needs enhancement and enjoy high-speed wireless performance without any hassles.
Works With Any Wireless Router
Universal compatibility and easy web-based iQ Setup for quick and easy installation.
Smart iQ Setup
Features user-friendly browser-based iQ Setup for smart, automatic and quick installation. iQ Setup automatically detects the available Wi-Fi networks nearby and helps you establish a connection within seconds.
Quick And Easy WPS Installation
A WPS (Wi-Fi Protected Setup) button allows the EW-7438RPn Mini to join an existing wireless networking at the simple push of a button.
Wireless 802.11n Standard (Data Rates Up To 300Mbps)
802.11n technology is built into the EW-7438RPn Mini to broaden its wireless coverage and eliminate dead spots within wireless range. The EW-7438RPn Mini is also backward compatible with wireless 802.11b/g/n standards and can reach data transmission rates of up to 300Mbps when connected to wireless 802.11n devices, providing faster and more reliable wireless connections than standard 802.11b/g wireless networks.
Wi-Fi Scheduling (Wi-Fi extender mode only)
The Wi-Fi scheduling function lets you program intelligent schedules to manage Wi-Fi availability and power usage according to your home’s routine.
Guest Network (Wi-Fi extender mode only)
The EW-7438RPn Mini also features a guest wireless network which could be used for visitor and keep your home Wi-Fi private and secure. (Wi-Fi extender mode only)
Signal Strength LED Indicator
Designed with a signal strength LED which helps you find the best setup location for optimal Wi-Fi coverage.
Edimax EW-7438RPn Mini - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
AC 120/230 V ( 50/60 Hz )
4.2 cm x 3.8 cm x 6.5 cm
4.2 cm
3.8 cm
6.5 cm
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Power, signal strength, LAN, wireless
Access Point operational mode, Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal
Antenna Qty
2
1 x 100Base-TX - RJ-45
FCC, RoHS, EAC
Internal power supply
10 - 90% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Not easy to set up
Reviewed by Geoff L on 19/07/2016
The instructions included with the range extender did not match up with what was actually happening. Being a keen computer hobbyist, I have set up extenders before so knew enough to get it working eventually. It was not easy - and for tat, a low rating.
Scroll to top
