BT.com
Wishlist
Edimax N300 Long Range Ceiling Mount Wireless Access Point
Edimax N300 Long Range Ceiling...
£40.40
£40.40
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The CAP300 is a reliable and affordable entry level wireless access point designed to meet the needs of modern small to medium sized businesses, with IEEE802.11n wireless speeds up to 300Mbps. Industrial-grade performance and build quality combined with user-friendly operation, an extensive feature set and a practical, ceiling-mount design make an ideal product for day-to-day enterprise use.
For businesses that demand security, flexibility and speed - the Edimax Pro series has a wide range of potential applications from office environments to schools, campuses, hotels and hospitals. Multiple SSIDs can be configured for different departments or user groups and a built-in Radius server provides additional verification with a scalable AP array architecture for central management of multiple access points.
Fast roaming for seamless transitions between access points, Power over Ethernet support (PoE) and an intuitive web-based management interface provide flexibility for deployment and extensive management options for company MIS departments and network administrators.
When performance and security are critical for your business, you need products that are engineered for your industry. The Edimax Pro series is designed to help your business and provide the connectivity that you rely on every day, with safety and effectiveness guaranteed.
  • 802.11N High Speed
  • Easy Installation
  • Compact & Durable Housing
  • Designed for High Density Usage
  • Multiple SSIDs for Security Management
  • Fast Roaming
  • Wide Coverage & High Sensitivity
  • Seamless Mobility
  • Power over Ethernet
  • Built-In RADIUS Server
  • Business Environments
  • Central Management
Edimax Pro CAP 300 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
17.6 cm x 17.6 cm x 3.2 cm
287.3 kg
Radio access point
17.6 cm
17.6 cm
3.2 cm
287.3 kg
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz
Status Indicators
Power, diagnostic
Power over Ethernet (PoE), VPN support, VLAN support, manageable, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), RADIUS support, roaming function, Wi-Fi Protected Setup (WPS), Multiple SSID support, hidden SSID, reset button, Management Information Base (MIB), ceiling mountable, DiffServ Code Point (DSCP) support
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2.82 dBi
1 x 1000Base-T (PoE) - RJ-45
FCC, RoHS, UL 94
PoE
6.5 Watt
50 °C
0 - 90%
Other bundles
Edimax N300 Long Range Ceiling Mount Wireless Access...
£40.40
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£43.88
Scroll to top
