BT.com
Wishlist
Edimax N150 Wireless USB Adapter with 3 dBi Antenna
Edimax N150 Wireless USB Adapter...
£11.73
38 in stock
£11.73
Add to wishlist
Delivery
Standard 3-5 working days
The EW-7711UAn is a high-gain USB Wi-Fi adapter which provides a simple and easy way to add or upgrade wireless connectivity to your desktop or notebook computer. This adapter supports fast data rates up to 150 Mbps when connecting with typical 802.11n Wi-Fi routers. Just plug it into your computer’s USB port for quick and easy Wi-Fi.
Edimax EW-7711UAn V2 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 15.5 cm x 1.5 cm
13 g
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External integrated
Antenna Qty
1
Gain Level
3 dBi
1 x USB extension cable (external)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
1.5 cm
15.5 cm
1.5 cm
13 g
0 - 95% (non-condensing)
Scroll to top
