BT.com
Wishlist
Edimax Gigabit Ethernet 5 Ports Desktop Switch
Edimax Gigabit Ethernet 5 Ports...
£13.75
Hurry, only 1 left in stock!
£13.75
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
5-Port Gigabit Desktop Switch
  • Complies with IEEE802.3, IEEE802.3u and IEEE802.3ab standards
  • Supports auto MDI/MDI-X crossover detecting and auto correction
  • Supports full and half duplex for 10/100Mbps, and full duplex for 1000Mbps
  • Wire-speed packet filtering and forwarding rate
  • Store-and-forward architecture filters fragment & CRC error packets
  • Supports jumbo frames up to 9K bytes
  • Supports IEEE802.3az energy efficient Ethernet function
  • Supports optional power supply either through a USB port or the AC power supply. (*USB power cable included. Requires 1A current-USB adapter not included.)
The ES-5500G V3 is a 10/100/1000 Mbps Gigabit Desktop unmanaged switch designed to enhance network performance in a compact form factor, and with outstanding performance and high efficiency. The switch uses store and forward packet-switching technology which offers reliable data transfer. This switch is ideal for network connectivity for the SOHO environment.
The ES-5500G V3 with plastic housing offers a cost-effective Gigabit Ethernet solution for users to easily extend home networks and to fulfill their online gaming, multimedia transferring and streaming needs. The plug-and-play design allows users to easily connect network devices such as PCs, network storages and print servers to the home network without manual configuration involved.
Edimax ES-5500G V3 - switch - 5 ports - unmanaged - desktop
Switch - 5 ports - unmanaged
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
Flow control, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, half duplex mode, full duplex mode, USB powered, Jumbo Frames support, plastic housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
7.1 cm x 9.8 cm x 2.55 cm
112 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
2K entries
Jumbo Frame Support
9KB
Status Indicators
Power, link/activity
5 x 1000Base-T - RJ-45 , 1 x USB (power only)
External power adapter
2 Watt
1 x USB power cable
Plug and Play, FCC Class B certified, RoHS
7.1 cm
9.8 cm
2.55 cm
112 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
