BT.com
Wishlist
Edimax Fast Ethernet IP Camera
Delivery
Standard Due date unavailable
No need to worry about complex network setup procedures. The install wizard can provide easy setup procedure to use camera.
This Internet camera allows multiple users login to view live video simultaneously. The advanced video compression produces a high-quality, high-frame rate, VGA, QVGA video stream.
The Internet camera delivers complete, high-quality pictures in standard JPEG format, which can be viewed using any standard browser.
These tools allow users to access the Internet camera from a remote site via Intranet or Internet. They also provide users to make function configuration including image monitoring, recording images to a hard drive, viewing up to 4 cameras on one screen, snapshots and so on.
The camera also supports UPnP and DDNS. DDNS allows the camera to use an easier to remember naming format rather than an IP address. UPnP will allow users of Windows XP to access the camera with the click of a mouse without knowing IP address of the camera.
Edimax IC-1510 - network surveillance camera
Network surveillance camera - fixed
7.9 cm x 5 cm x 11.4 cm
Wired
Camera
Optical Sensor Type
CMOS 0.3 MP
Focus Adjustment
Manual
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V
Motion Detection Technology
Environmental Parameters (operating)
10 - 90% relative humidity
Wired
7.9 cm
5 cm
11.4 cm
Camera
Colour - fixed
Digital Video Format
AVI, MJPEG
Still Image Capture Resolution
640 x 480, 320 x 240, 160 x 120
RAM
16 MB
Flash Memory
2 MB
Image Sensor
0.3 MP CMOS
Lens Construction
Focus Adjustment
Manual
Network Interface
Network Protocols
HTTP
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
C-Tick, FCC
Power Requirements
DC 12 V - 0.4 A
Relative Humidity (operating)
10 - 90%
Scroll to top
