BT.com
Wishlist
Edimax Fast Ethernet 8 Ports Desktop Switch
Edimax Fast Ethernet 8 Ports...
£7.34
£7.34
Add to wishlist
Delivery
Standard Due date unavailable
The ES-3308P V3 is a 10/100 Mbps unmanaged Ethernet desktop switch designed to enhance network performance. It’s compact, sleek design offers outstanding performance and high efficiency, using store and forward packet-switching technology to provide reliable data transfers, ideal for network connectivity in the SOHO environment.
To extend home networks or meet streaming, multimedia transfer and online gaming requirements the ES-3308P V3 is a cost-effective Fast Ethernet solution. The plug-and-play design ensures users can easily connect network devices such as PCs, network-attached storage or print servers to a home network with no manual configuration necessary.
Compact Design & Flexible Placement
Designed for easy home network extension with desktop and wall-mount installation for flexible placement. It’s compact size fits into the home environment and keeps desk space free.
Easy to Use
The ES-3308P V3 is plug-and-play and supports a wide range of network protocols. Installation and network management is quick and straightforward while clear and convenient LED indicators display easy-to-read port and switch status.
High Performance
The ES-3308P V3 switch also supports auto-negotiation and non-blocking wire speed to give you the maximum speed and highest performance possible for each device connected to your network.
Auto-Negotiation
Each of the ES-3308P V3’s ports automatically detect whether connected network devices are running at 10Mbps or 100Mbps and half-duplex or full-duplex mode, and adjusts the speed and mode accordingly ensuring easy and hassle-free operation.
Non-Blocking Wire Speed
Forwards and receives traffic seamlessly - each port supports speeds up to 200Mbps in full-duplex mode simultaneously, providing full wire speed to connected devices and allowing you to run a high speed network smoothly.
Power Saving
Along with the Fast Ethernet speeds critical for next-generation network applications, the ES-3308P V3 offers environmental efficiency . To comply with the IEEE802.3az standard, the ES-3308P V3 provides power saving functionality to reduce energy consumption and save costs.
Inactive Link Detection
When a network device is shut down and/or an inactive link is detected, the power usage adjustment feature automatically reduces power usage. The switch’s power consumption will be dynamically adjusted according to the link status and the number of active network devices.
Cable Length Detection
Devices equipped with this feature automatically detect the length of connected Ethernet cables and adjust power usage accordingly. The shorter the cable length, the less power it consumes.
APPLICATION DIAGRAM
  • Connect the ES-3308P V3 to your router or cable/xDSL modem.
  • Connect a print server, NAS, smart TV, laptop, media player, game console and/or IP Camera to the ES-3308P V3.
Edimax ES-3308P V3 - switch - 8 ports - unmanaged - desktop
Switch - 8 ports - unmanaged
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
1K entries
Auto-negotiation, store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
RAM
56 KB
Status Indicators
Power, link/activity
8 x 100Base-TX - RJ-45
External power adapter
2 Watt
Plug and Play, FCC Class B certified
8.8 cm
8.8 cm
2.5 cm
86 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
