BT.com
Wishlist
Edimax Fast Ethernet 8 Port Smart Managed Switch
Edimax Fast Ethernet 8 Port Smart...
£134.78
£134.78
Add to wishlist
Delivery
Standard 1-3 working days
The Edimax ES-5208P is a web-smart switch with 8 fast Ethernet PoE+ ports and 2 Gigabit combo ports. It easily connects and supplies power to PoE-enabled devices such as wireless access points, network cameras and IP phones as well as other Ethernet-enabled devices such as computers, printers and network attached storage (NAS). ES-5208P is designed with easy management, all configuration can be performed through an intuitive browser-based Graphical User Interface. Ideal for small or medium network environments to strengthen the network connection, its standard rack-mount brackets allow for integration with the most widely used mounting systems on the market.
Edimax ES-5208P - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 2.8 Gbps
MAC Address Table Size
4K entries
Jumbo Frame Support
1536 bytes
Remote Management Protocol
HTTP
Flow control, full duplex capability, auto-negotiation, IGMP snooping, packet filtering, port mirroring, store and forward, Broadcast Storm Control, Quality of Service (QoS), reset button, bandwidth control, 352KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at
33 cm x 23 cm x 4.4 cm
2.3 kg
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
4K entries
Jumbo Frame Support
1536 bytes
HTTP
Status Indicators
Power, system, PoE, link/activity
24 x 100Base-TX - RJ-45 - PoE+ - 30 W , 2 x 1000Base-T - RJ-45 , 2 x - SFP
Internal power supply
390 Watt
Rack Mounting Kit
Included
FCC
33 cm
23 cm
4.4 cm
2.3 kg
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
