BT.com
Wishlist
Edimax Fast Ethernet 5 Port Switch with 4 PoE+ Ports
Edimax Fast Ethernet 5 Port Switch...
£42.62
£42.62
Add to wishlist
Delivery
Standard Due date unavailable
The Edimax ES-5104PH is a five Port Fast Ethernet switch with four PoE+ Ports designed for use in home, small or medium sized network environments. It easily connects and supplies power to PoE-enabled devices such as wireless access points, network cameras and IP phones as well as other Ethernet-enabled devices such as computers, printers and network attached storage (NAS). The device's compact size and fan-less design make it an ideal solution for expanding home and small business networks.
Features:
  • Five 10/100Mbps Fast Ethernet ports and four PoE+ ports.
  • IEEE 802.3af/at PoE compliant (ports 1 - 4) for simplified deployment and installation.
  • Up to 30W per PoE port (total power budget: 55W) for powering PoE-enabled devices.
  • Auto-detection of powered devices (PD) and power consumption levels.
  • 2K MAC address table and jumbo frames support up to 2KB.
  • Plug & play, no installation required.
  • Fanless quiet operation.
  • External power adapter included.
Edimax ES-5104PH - switch - 5 ports
Switch - 5 ports
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE+) + 1 x 10/100
Power Over Ethernet (PoE)
PoE+
PoE Budget
55 W
Performance
Switching capacity: 1 Gbps
MAC Address Table Size
2K entries
Jumbo Frame Support
2048 bytes
Flow control, full duplex capability, store and forward, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
16 cm x 9.25 cm x 2.8 cm
340 g
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
55 W
Performance
2K entries
Jumbo Frame Support
2048 bytes
Status Indicators
Power, PoE, link/activity
4 x 100Base-TX - RJ-45 - PoE+ - 30 W , 1 x 100Base-TX - RJ-45
Plug and Play, FCC, RoHS
16 cm
9.25 cm
2.8 cm
340 g
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
Scroll to top
