BT.com
Wishlist
Edimax Fast Ethernet 5 Port Desktop Switch
Edimax Fast Ethernet 5 Port Desktop...
£5.84
12 in stock
£5.84
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The ES-3305P V2 is plug-and-play and supports a wide range of network protocols. Installation and network management is quick and straightforward, and clear and convenient LED indicators display easy to read port and switch status. Along with the Fast Ethernet speeds critical for next-generation network applications, the ES-3305P V2 offers environmental efficiency. To comply with the IEEE802.3az standard, the ES-3305P V2 provides power saving functionality to reduce energy consumption and save costs.
Edimax ES-3305P V3 - switch - 5 ports - unmanaged - desktop
Switch - 5 ports - unmanaged
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
MAC Address Table Size
1K entries
Auto-negotiation, store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
8.8 cm x 8.8 cm x 2.5 cm
82 g
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
1K entries
RAM
48 KB
Status Indicators
Power, link/activity
5 x 100Base-TX - RJ-45
External power adapter
2 Watt
Plug and Play, FCC Class B certified
8.8 cm
8.8 cm
2.5 cm
82 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
