BT.com
Wishlist
Edimax EW-7811DAC AC600 Wireless Dual-Band Directional USB Adapter
Delivery
Standard Due date unavailable
The next generation 802.11ac wireless standard is set to revolutionize Wi-Fi. Super-speed 802.11ac dual-band routers are already available but wireless devices are still stuck with 802.11n technology. Upgrade your wireless device to dual-band 802.11ac with the USB 2.0 connectivity for blistering Wi-Fi speeds on the interference free 5 GHz frequency band. The EW-7811DAC is with a directional high gain, high-performance, and dual band antenna. This antenna can greatly increase the effective wireless operation range of 802.11 ac/a/b/g/n wireless devices.
Edimax EW-7811DAC - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
9 cm x 1.5 cm x 13.2 cm
36 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac (draft)
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.1x
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Wi-Fi Protected Setup (WPS), 802.1x authentication
IEEE 802.1x
Aerial
Antenna
External integrated
Antenna Qty
1
Gain Level
7 dBi
USB cradle
1 x USB cable - 1.2 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
9 cm
1.5 cm
13.2 cm
36 g
0 - 95% (non-condensing)
Scroll to top
