BT.com
Wishlist
Edimax AC750 Smart Dual-Band Wi-Fi Extender
Edimax AC750 Smart Dual-Band Wi-Fi...
£28.02
£28.02
Add to wishlist
Delivery
Standard Due date unavailable
The Edimax EW-7438AC is an 11ac high-speed smart Wi-Fi extender with built-in power adapter and a compact design which plugs directly into an electrical outlet. Double the signal coverage of your Wi-Fi network for better Wi-Fi quality around your home. With smart iQ Setup, installation is quick and easy and the EW-7438AC features three operating modes: Wi-Fi extender, access point or Wi-Fi bridge. Use whichever mode you need for your network. Additionally, the extender complies with IEEE 802.11ac and IEEE 802.11 a/b/g/n wireless standards, for concurrent dual-band wireless speeds up to 750Mbps (300Mpbs on 2.4GHz + 433Mbps on 5GHz). With the Edimax EW-7438AC you can enjoy high-speed wireless networking throughout your home without additional cabling. And the EW-7438AC works together with the free EdiRange smartphone app to provide local Wi-Fi environment analytics as well as Wi-Fi scheduling functions and guest network management.
11ac Super High-Speed Dual-Band Wi-Fi
Offers the latest 11ac Wi-Fi technology with high-speed capacity up to 750Mbps (N300 + AC433Mbps) and extends both 2.4GHz and 5GHz wireless connections at the same time.
Eliminate Dead Zones & Double Wi-Fi Coverage
Extend Wi-Fi coverage to dead zones which your existing Wi-Fi signal can’t reach. Plug the extender directly into an electrical outlet and double the signal coverage of your Wi-Fi network for better Wi-Fi quality across different rooms or multiple floors in your home.
Smart 3-in-1 Extender, Access Point and Wi-Fi Bridge
The EW-7438AC can work as Wi-Fi extender, access point or Wi-Fi bridge. Just configure the mode you need for your network environment using the smart iQ Setup wizard and enjoy surfing the web.
Smart iQ Setup
Features user-friendly browser-based iQ Setup for smart, automatic and quick installation. iQ Setup automatically detects the available Wi-Fi networks nearby and helps you establish a connection in a few seconds.
Smart App Control & Analytics
The extender works together with the free EdiRange smartphone app which displays your local Wi-Fi environment and provides easy-to-understand analytics. Plus you can manage the extender’s wireless network and functions such as scheduling and guest network.
Universal Compatibility, Works With Any Wireless Router
Universal compatibility and easy web-based iQ Setup for quick and easy installation.
Green Wi-Fi Power Switch
Featuring a new hardware switch to adjust between normal and green Wi-Fi transmit power (the strength of the Wi-Fi signal) or switch off the power with one click. If you only need Wi-Fi in a smaller house, you can switch to green mode to reduce transmit power by 75% and conserve energy.
Cross-Band Technology for Maximum Speed
Edimax cross-band technology uses both frequency bands together to maintain your router’s maximum speed capacity through your extender and to your Wi-Fi device. Data is transmitted on one band and received on the other band, meaning no speed loss at your extender and a faster network with better performance. Perfect for high-speed applications such as HD video streaming or online gaming.
Smart Signal-Strength Indicator
Designed with a signal strength LED which lets you see the Wi-Fi signal strength received from the router and guides you to find the best setup location.
Wi-Fi Scheduling
Program intelligent schedules to manage Wi-Fi availability and power usage according to your home’s routine.
Guest Wi-Fi
The EW-7438AC also features a guest wireless network which could be used for visitors only and help to keep your home Wi-Fi private and secure.
Edimax EW-7438AC - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
AC 120/230 V (50 - 60 Hz)
5.9 cm x 4 cm x 9.1 cm
106 g
5.9 cm
4 cm
9.1 cm
106 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, signal strength, LAN, wireless, WPS
Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
1 x 100Base-TX - RJ-45
FCC, RoHS
Internal power supply
10 - 90% (non-condensing)
Other bundles
£28.02
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£31.50
Scroll to top
