BT.com
Wishlist
Edimax AC600 Wireless Fast Ethernet Router
Edimax AC600 Wireless Fast Ethernet...
£40.08
£40.08
Add to wishlist
Delivery
Standard Due date unavailable
AC600 Multi-Function Dual-Band Wi-Fi Router,Access Point, Range Extender, Wi-Fi Bridge & WISP
To meet today’s high-speed connectivity needs, Edimax has launched the BR-6288ACL dual-band 802.11ac router with the latest 11ac standard for extraordinary improvements in the speed, reliability and quality of wireless communications. It’s a 5-in-1 dual-band Wi-Fi router with an easy 3-step setup using a smartphone app or web-based smart iQ setup, which meets all of your Wi-Fi demands and is the first product of its kind to feature a green, power-saving TX power switch to adjust the Wi-Fi signal strength. The smartphone app and web-based interface also support auto firmware upgrade and the sleek design provides a unique, space-saving aesthetic which blends with any interior and delivers wide-reaching Wi-Fi coverage.
  • Next generation 802.11ac Wi-Fi standard
  • 5-in-1 Router, Access Point, Range Extender, Wireless Bridge and WISP
  • Backward compatible with 802.11a/b/g/n standards
  • Concurrent dual-band wireless connectivity for 2.4GHz and 5GHz
  • Smartphone App & Smart iQ Setup
  • Auto Firmware Upgrade
  • Green Wi-Fi TX Power Switch
  • High gain internal antenna for better Wi-Fi performance
  • Supports up to 8 Multi-SSID (2.4GHz x 4 and 5GHz x 4) & VLAN (AP mode only)
  • Supports guest network (router mode only)
  • Revolutionary iQoS for efficient and effective internet bandwidth management
  • Powered by USB
Edimax BR-6288ACL - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
Routing Protocol
IGMP, static IP routing
Firewall protection, DMZ port, DHCP support, VLAN support, IGMP snooping, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, manageable, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, Access Point operational mode, firmware upgradable, USB powered, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough, Multiple SSID support, wireless bridge mode, reset button, port triggering, iQoS, static routing, Wireless Intrusion Prevention System (WIPS), IGMP proxy, PPTP passthrough, wireless extender mode
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
7 cm x 7 cm x 21.5 cm
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC
RAM
64 MB
Flash Memory
4 MB
Status Indicators
Status
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x
Aerial
Aerial
Internal
Network splitter
1 x USB cable , 1 x network cable
Software Included
Drivers & Utilities
7 cm
7 cm
21.5 cm
10 - 90% (non-condensing)
Scroll to top
