BT.com
Wishlist
Edimax AC1750 Outdoor Dual-Band PoE Access Point
Edimax AC1750 Outdoor Dual-Band PoE...
£409.40
£409.40
Add to wishlist
Delivery
Standard 1-3 working days
The OAP1750 features an IP67 rated weatherproof and rust-resistant metal casted housing and provides a premium wireless solution designed for SMBs which demand elite network performance. The product features the latest 3 x 3 IEEE 802.11ac technology for concurrent dual-band wireless speeds up to 1750Mbps. A wall or pole-mounted design and industrial-grade build quality combined with user-friendly operation and extensive feature set, make an ideal high-performance dual-band solution for demanding day-to-day enterprise operations.
For businesses that demand security, flexibility and speed - the Edimax Pro series has a wide range of potential applications from office environments to schools, campuses, hotels and hospitals. Multiple SSIDs can be configured for different departments or user groups and a built-in RADIUS server provides additional verification with a scalable AP array architecture for central management of multiple access points. High-density capacity for up to 100 simultaneous clients ideal for BYOD workplaces or other environments with a high volume of clients and wireless devices, and fast roaming allows for seamless transitions between multiple access points. Power over Ethernet support (PoE) and an intuitive web-based management interface provide deployment flexibility and extensive management options for company MIS departments and network administrators.
When performance and security are critical for your business, you need products that are engineered for your industry. The Edimax Pro series is designed to help your business and provide the connectivity that you rely on every day, with safety and effectiveness guaranteed, and the OAP1750 offers the highest level of wireless performance on the market today.
Edimax OAP1750 - radio access point
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs (2.4 Ghz): 16 , Maximum number of configured SSIDs (5 Ghz): 16 , Concurrent users per radio: 50 , Virtual interfaces (VLANs): 4095
Power Over Ethernet (PoE) Supported
PoE+
22.67 cm x 25.67 cm x 9.03 cm
2.98 kg
Radio access point
Ruggedized Design
Outdoor
22.67 cm
25.67 cm
9.03 cm
2.98 kg
External
Wireless
Data Transfer Rate
1.75 Gbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, WLAN, LAN
VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Rapid Spanning Tree Protocol (RSTP) support, IPSec passthrough, hidden SSID, pole mountable, 3T3R MIMO technology, rogue access point detection, DiffServ Code Point (DSCP) support, PPTP passthrough, L2TP passthrough
Encryption Algorithm
PEAP, WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T (PoE+)
FCC
PoE+
22 Watt
-40 °C
70 °C
0 - 90%
Other bundles
£409.40
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£412.88
Scroll to top
