BT.com
Wishlist
Edimax AC1200 Dual-Band USB Adapter
Delivery
Standard Due date unavailable
The Edimax EW-7822UAC is the Wi-Fi adapter, compatible with the draft 802.11ac standard. The EW-7822AC is the adapter of its kind to offer 802.11ac speeds together with USB 3.0 connectivity.
The EW-7822UAC's sleek design features an adjustable foldaway antenna, allowing users to adjust the antenna's angle for optimum Wi-Fi performance and fold back the antenna to minimize size when it's not in use.
Edimax EW-7822UAC - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
2.7 cm x 8.71 cm x 1.8 cm
23 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac (draft)
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, USB 3.0, Wi-Fi Protected Setup, IEEE 802.11ac (draft)
Microsoft Windows Vista / XP / 7, Windows 8
Network adapter
External
SuperSpeed USB 3.0
Wireless
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External integrated and internal
Antenna Qty
2
1 x SuperSpeed USB 3.0 - 9 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
PCT, FCC Part 15 B, R&TTE, RoHS, WEEE
Software Included
Drivers & Utilities, EZmax Setup Wizard
2.7 cm
8.71 cm
1.8 cm
23 g
0 - 95% (non-condensing)
Scroll to top
