BT.com
Wishlist
Edimax 8-Port Gigabit PoE+ Switch
£136.84
£136.84
Add to wishlist
Delivery
Standard 1-3 working days
The GS-1008P is an 8-port 10/100/1000BASE switch with 8 PoE ports, designed for use in small or medium sized network environments. This product is compact in size, making it ideal for users with limited space. It also gives users the option of installing it in a 19" cabinet with rack-mount kits or underneath a desk.
Complies with IEEE 802.3at Power over Ethernet (PoE)
The GS-1008P features 8 IEEE 802.3at Power over Ethernet (PoE) ports, which supply up to 30 watts of power per port. It can convert standard 100-240V AC power into low-voltage DC, which runs over existing LAN cables to supply power to IEEE 802.3at compliant network accessories. The GS-1008P also features PoEdetection, to verify whether the connected device is IEEE 802.3at compliant; if it is not a PoE device, only data will be sent through the LAN cable. The GS-1008P can connect with a variety of PoE products, including access points, IP cameras and IP phones. It is the best solution for when power outlets are difficult to install or the power outlets are too far from the device.
No Special Networking Cable Required
The standard Cat-5 Ethernet cable is used to link the GS-1008P and the powered devices. This Ethernet cable can transmit both data and power. No separate power cable is needed for the powered devices, thus reducing installation time and costs.
Fan-Less Design
Since the fan-less design ensures quiet operation in small office spaces, the GS-1008P is an ideal solution for SOHO environments.
Edimax GS-1008P - switch - 8 ports
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
145 W
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Store and forward, Jumbo Frames support, fanless, over-current protection, over-voltage protection, undercurrent protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
26.6 cm x 18.4 cm x 4.4 cm
1.5 kg
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
145 W
8K entries
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, link/activity
8 x 1000Base-T - RJ-45 - PoE+
Internal power supply
5 Watt
FCC Class B certified
26.6 cm
18.4 cm
4.4 cm
1.5 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Scroll to top
