BT.com
Wishlist
Edimax 300Mbps Wireless PCI-E Adapter V2
Edimax 300Mbps Wireless PCI-E...
£13.03
£13.03
Add to wishlist
Delivery
Standard Due date unavailable
The Edimax EW-7612PIn V2 N300 Wireless PCI Express Adapter is an easy way to add Wi-Fi connectivity to your desktop computer. Built with the 802.11n standard, 2T2R MIMO technology, and two high-gain 3 dBi detachable antennas, this wireless PCIe adapter allows for fast and stable wireless networking with data speeds of up to 300Mbps. It can be easily set up with the bundled EZmax multi-language setup wizard, and it comes with a low-profile bracket for installation on small computers.
Edimax EW-7612PIn V2 - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
12.1 cm x 8.8 cm x 2.2 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7 / 8
Network adapter
Plug-in card
PCI Express
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link activity, transmit, receive
Wi-Fi Protected Setup (WPS), 802.1x authentication
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
3 dBi
2 x aerial - RP-SMA
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Software Included
EZmax Setup Wizard
12.1 cm
8.8 cm
2.2 cm
10 - 90% (non-condensing)
Scroll to top
