BT.com
Wishlist
Edimax 300Mbps Wireless miniUSB adapter
Edimax 300Mbps Wireless miniUSB...
£11.74
10 in stock
£11.74
Add to wishlist
Delivery
Standard 3-5 working days
The EW-7722UTn V2 is a high-speed wireless USB adapter that boasts maximum range and speed. This wireless USB adapter can achieve data transfer rates of up to 300 Mbps when connected to wireless 802.11n devices, which is 5 times faster than a 802.11g connection. Enjoying high-speed wireless network access is as simple as plugging the Edimax EW-7722UTn V2 into your computer's USB port. This is for sure the trendiest way to upgrade your wireless network connectivity.
Edimax EW-7722UTn V2 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.58 cm x 1.78 cm x 0.91 cm
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB extension cable ( external )
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Software Included
EZmax Setup Wizard
3.58 cm
1.78 cm
0.91 cm
10 - 90% (non-condensing)
Scroll to top
