Click to visit BT.com
BT.com
Wishlist
Edimax 11N 150 Hi-Gain USB adaptor
3.0*
Quicklinx: 5BW1WS00
Mfr#: EW-7711UAN
EW-7711UAn is a high-gain wireless USB adapter which provides a simple and easy way to add or upgrade wireless connectivity to your desktop or notebook computer. This nLITE high-gain USB adapter supports higher data rate up to 150Mpbs when connecting with wireless 802.11n device. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access.
Compatible with wireless 802.11n devices with data rate up to 150Mbps
EW-7711UAn complies with wireless 802.11b/g standards. With built-in with the latest wireless technology, EW-7711UAn can increase the coverage 3 times more and reduce "dead spots" within the wireless range. The transmission data rate when connecting with wireless 802.11n devices is up to 150Mbps, which makes signal travel farther and maintain wireless connections much reliable than standard wireless 802.11b/g network.
Supports WPS-compatible (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS-compatible configuration and hardware WPS push button. When both ends of the wireless connection use wireless solution with WPS, it will automatically configure the wireless network with robust WPA data encryption and authentication.
Supports multi-language EZmax setup wizard
The included 16 languages EZmax setup wizard and friendly UI will walk you through configuring EW-7711UAn to your wireless network.
Portable and compact design
Rotatable 3dBi high gain antenna makes the wireless transmission more stable and reach farther. The compact design of EW-7711UAn is convenient to carry for all mobile users.
Key Features
Also compatible with 802.11b/g products
Supports data transfer rates of up to 150Mbps
Supports WEP, WPA and WPA2
Supports Windows 2000/xp/vista, MAC 10.4x and above and Linux
  • Compatible with wireless 802.11n devices with data rate up to 150Mbps
  • Supports WPS-compatible (Wi-Fi Protected Setup) button
  • Supports multi-language EZmax setup wizard
  • Portable and compact design
    EA-7711UAn is currently the smallest wireless adapter. Its rotatable 3dBi high gain antenna makes the wireless transmission more stable and reach farther. The compact design of EW-7711UAn is convenient to carry for all mobile users.
Edimax EW-7711UAn - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 15.5 cm x 1.5 cm
802.11b, 802.11g, 802.11n (draft)
Data Transfer Rate
150 Mbps
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Apple MacOS, Microsoft Windows Vista / 2000 / XP
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Status Indicators
Link activity
Aerial
Antenna Qty
1
Gain Level
3 dBi
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
1.5 cm
15.5 cm
1.5 cm
Customer reviews
Write a review for the Edimax 11N 150 Hi-Gain USB adaptor here!
Good product - avoid software
Reviewed by Graeme. Review Posted 04/12/2008
Good design/quality and gain (range) is spot on.
Only pain in the butt was making the mistake of installing their wireless LAN software which is best avoided - conflicted badly with XPP which battled for control and just led to constant connection/disconnection. Uninstalled it and just used the drivers and it works fine.
  • Overall 4*
  • Ease of use 4*
  • Value for money 5*
Working with an Apple Mac
Reviewed by Willie. Review Posted 18/12/2008
A bit tricky getting set up with a Mac, OS10. Works most of the time, but frequent re-configurations required when it does not work automatically.
Still does the job most of the time.
Not used with a PC.
  • Overall 4*
  • Ease of use 3*
  • Value for money 4*
Consider other products!
Reviewed by Mike Booth. Review Posted 15/10/2009
I bought 2 and have wasted hours over the last few weeks finding out what the trouble is. 1 was for a laptop the other a desktop. Both are problematic. Network dips out, even when close to router. Can't suspend laptop as network disappears completely. Tried it on b/g/n 20/40 etc. etc. but always the signal is not there and requires a reboot, or is very flakey when connected. Connection rates constantly changes between 5Mbps and 65 or somewhere in between. I've emailed Edimax and 2 weeks later I'm not hopeful of any reply so have purchased a Dynamode adaptor. I installed this last night and although the instructions where wrong on the installation process have managed to get it installed. The connection is rock solid. I can even close the lid on the laptop now and resume it with networking. I've been warned about USB adaptors but thought they would work for me, but from this experience I would stay clear. Also not good that Edimax can't be bothered to return support emails.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
  • Overall 1*
  • Ease of use 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
