BT.com
Wishlist
Eaton PW9130i1500T-XL - UPS - 1.35 kW - 1500 VA
Eaton PW9130i1500T-XL - UPS - 1.35...
£797.67
16 in stock
£797.67
Add to wishlist
Delivery
Standard 1-3 working days
The Eaton 9130 UPS delivers online power quality and scalable battery runtimes for servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of 95% in online double conversion and 98% in high efficiency mode the 9130 UPS cuts energy costs while significantly extending battery service life with ABM technology. The 9130 UPS also has a bright LCD user interface to simplify monitoring.
UPS - external
19 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
1.35 kW / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid - 9 Ah
Battery Form Factor
Internal
Batteries Qty
4
Run Time (Up To)
5 min at full load
RS-232, USB
Cable retention brackets
16 cm x 43 cm x 23 cm
2 years warranty
UPS - external
Battery Enclosure Type
Internal
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 276 V
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3%
Power Capacity
1.35 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Efficiency
95%+
Quantity
4
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
5 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Communication slot
USB cable - external
Advance Battery Management (ABM), audible alarm, LCD display, internal bypass, LED indicators, automatic self-test
GS, EN 62040-2
Software Included
Eaton Software Suite
Limited warranty - parts and labour - 2 years
5 - 90% (non-condensing)
Sound Emission
50 dB
16 cm
43 cm
23 cm
19 kg
Scroll to top
