BT.com
Wishlist
Eaton PW9130i1500R-XL2U
£897.30
Hurry, only 1 left in stock!
£897.30
Add to wishlist
Delivery
Standard 1-3 working days
The Eaton 9130 Rackmount UPS delivers online power quality and scalable battery runtimes for rack servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of >95%, the 9130 UPS cuts energy costs while packing up to three kVA of power into only 2U of rack space. The 9130 UPS significantly extends battery service life with ABM technology and also has a bright LCD user interface to simplify monitoring.
Eaton PW9130i1500R-XL2U - UPS - 1.35 kW - 1500 VA
UPS - rack-mountable
Rack Size
2U
19 kg
Input Voltage
AC 220-240 V
Output Voltage
± 3%
Power Capacity
1.35 kW / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid 9 Ah
Battery Form Factor
Plug-in module
Run Time (Up To)
18 min at half load
RS-232, USB
43.8 cm x 45 cm x 8.65 cm
3 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 220-240 V
Input Voltage Range
AC 180 - 276 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
± 3%
Power Capacity
1.35 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Efficiency
94%
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
18 min at half load , 11 min at 75% load
Maintenance free, sealed
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Communication slot
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
Advance Battery Management (ABM), LCD display, internal bypass, LED indicators, automatic self-test, Remote Emergency Power Off (REPO), hot-swappable batteries
GS, IEC 62040-2, EN 62040-2
Software Included
Eaton Software Suite
Limited warranty - parts and labour - 3 years , Limited warranty - parts and labour - batteries - 2 years
5 - 90% (non-condensing)
Sound Emission
44 dB
43.8 cm
45 cm
8.65 cm
19 kg
Scroll to top
