BT.com
Wishlist
Eaton PW5130i3000-XL3U
£679.44
£679.44
Add to wishlist
Delivery
Standard Due date unavailable
The Eaton 5130 Rack Tower UPS provides line-interactive backup power and scalable runtimes for servers, storage systems, VoIP gear and network equipment. With a two-in-one rack/tower form factor. To enhance compatibility with modern IT loads, the 5130 UPS is designed with a 0.9 power factor.
Eaton PW5130i3000-XL3U - UPS - 2.7 kW - 3000 VA
UPS - external
Rack Size
3U
34.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 184-265 V
Power Capacity
2.7 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid 7.2 Ah
Battery Form Factor
Internal
Run Time (Up To)
3 min at full load
RS-232, USB
Screwdriver, tower stand, cable retention brackets
44.1 cm x 48.4 cm x 13.07 cm
3 years warranty with product registration
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
3U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 294 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 184-265 V
Power Capacity
2.7 kW / 3000 VA
Surge Suppression
Efficiency
94%+
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
3 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B
Expansion Slots
1 Communication slot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LED indicators, over voltage protection, undervoltage protection
FCC Class A certified, UL, TUV, C-Tick, ANSI C62.41, cUL, UL 1778, UL 497A, IEC 60950, FCC Part 15, EN 50091-2, CSA C22.2 No. 107.1, EN 50091-1
Software Included
Eaton Intelligent Power Software Suite
Limited warranty - parts and labour - 3 years
35 °C
20 - 95% (non-condensing)
Sound Emission
45 dB
44.1 cm
48.4 cm
13.07 cm
34.3 kg
Scroll to top
