BT.com
Wishlist
Eaton PW5130i1250-XL2U
£519.97
£519.97
Add to wishlist
Delivery
Standard Due date unavailable
The Eaton 5130 Rack Tower UPS provides line-interactive backup power and scalable runtimes for servers, storage systems, VoIP gear and network equipment. With a two-in-one rack/tower form factor, the 5130 UPS packs up to three kVA of power into only 2U of rack space. The 5130 UPS provides additional battery runtime with 2U extended battery modules. To enhance compatibility with modern IT loads, the 5130 UPS is designed with a 0.9 power factor.
Eaton PW5130i1250-XL2U - UPS - 1.15 kW - 1250 VA
UPS - external
Rack Size
2U
24.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 184-265 V
Power Capacity
1.15 kW / 1250 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid 7.2 Ah
Battery Form Factor
Internal
Run Time (Up To)
5 min at full load
RS-232, USB
Screwdriver, tower stand, cable retention brackets
44.1 cm x 50.9 cm x 8.62 cm
3 years warranty with product registration
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 294 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 184-265 V
Power Capacity
1.15 kW / 1250 VA
Surge Suppression
Efficiency
94%+
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
5 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) management - RS-232 - RJ-45 , 1 x management (USB) management - USB - 4 pin USB Type B
Expansion Slots
1 Communication slot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LED indicators, over voltage protection, undervoltage protection
FCC Class A certified, UL, TUV, C-Tick, ANSI C62.41, cUL, UL 1778, UL 497A, IEC 60950, FCC Part 15, EN 50091-2, CSA C22.2 No. 107.1, EN 50091-1
Software Included
Eaton Intelligent Power Software Suite
Limited warranty - parts and labour - 3 years
20 - 95% (non-condensing)
Sound Emission
45 dB
44.1 cm
50.9 cm
8.62 cm
24.3 kg
Scroll to top
