BT.com
Wishlist
Eaton ePDU MO 0U (C20 16A 1P) 20XC13:4XC19
Eaton ePDU MO 0U (C20 16A 1P)...
£655.27
£655.27
Add to wishlist
Delivery
Standard Due date unavailable
ePDU G3 Metered Outlet models allow device level metering over multiple power feeds, and includes kWh, peak power and current draw. Clearly view and understand the consumption of individual devices powered over A and B feeds and see available power. Metered Outlet units have no switching. They include IEC Class 1 (±1%) billing grade accuracy, an advanced hot-swap meter with LCD pixel display showing V, W, A and kWh, and the ability to daisy chain 8 ePDUs to share the same network connection and IP address.
Eaton ePDU G3 Metered Outlet - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Connectors
1 x power IEC 60320 C20 16A
Output connectors
20 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Ethernet 10/100, RS-232
5.2 cm x 5.3 cm x 160.4 cm
Height (Rack Units)
0U
Input Connectors
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
Power cable - integrated
LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
60 °C
5.2 cm
5.3 cm
160.4 cm
Scroll to top
