BT.com
Wishlist
Eaton ePDU MI 0U (309 32A 3P) 30XC13:12XC19
Eaton ePDU MI 0U (309 32A 3P)...
£1,173.68
£1,173.68
Add to wishlist
Delivery
Standard Due date unavailable
Eaton G3 Metered Input ePDUs provide a best-in-class design featuring billing grade accuracy monitoring of input and branch circuits on a local LCD pixel display or over a network connection. The high accuracy meter will measure current, voltage, power and energy for load balancing, capacity planning, efficiency monitoring and energy usage reporting. Designed for IT and data center applications means high reliability and a robust design made for high operating temperatures found in containment or networking closets.
Eaton ePDU G3 Metered Input - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Wiring
3-phase
Input Connectors
1 x power IEC 60309 32A
Output connectors
30 x power IEC 60320 C13 , 12 x power IEC 60320 C19
Ethernet 10/100, RS-232
5.2 cm x 6.5 cm x 182.9 cm
Height (Rack Units)
0U
Input Voltage Range
AC 200 - 240 V
Input Wiring
3-phase
Frequency Required
50/60 Hz
Input Connectors
Circuit Protection
Circuit breaker
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
Power cable - integrated - 3 m
LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
CB
60 °C
5.2 cm
6.5 cm
182.9 cm
Scroll to top
