BT.com
Wishlist
Eaton ePDU In-Line Metered - IEC60309 32A 3P Output 1XIEC60309
Eaton ePDU In-Line Metered -...
£342.04
£342.04
Add to wishlist
Delivery
Standard Due date unavailable
New ePDU G3 In Line Metered Input models upgrade existing basic installation to include, including ±1% billing grade accuracy, an advanced LCD pixel display, a hotswap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address
Eaton ePDU G3 In-Line Monitored - power monitoring unit - 22 kW
Power monitoring unit - rack-mountable
Rack Size
0U
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 400 V
Power Capacity
22 kW
Input Connectors
1 x power IEC 60309 32A
Output connectors
Ethernet, RS-232
44.3 cm x 5.3 cm x 5.2 cm
Height (Rack Units)
0U
Input Voltage
AC 400 V
Input Voltage Range
AC 346 - 415 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 400 V 50/60 Hz
Max Electric Current
32 A
Power Capacity
22 kW
Remote Management Interface
Ethernet, RS-232
1 x monitoring , 1 x management (Ethernet) , 1 x management (RS-232)
2 x power cable - integrated - 3 m
LED display, voltage monitoring, current meter
CB
60 °C
44.3 cm
5.3 cm
5.2 cm
Scroll to top
