BT.com
Wishlist
Dynamode DH-660 USB Stereo Headset
£11.72
£11.72
Add to wishlist
Delivery
Standard Due date unavailable
Yes that's right! The new DH-660-USB from Dynamode is a full Skype compatible USB-powered Stereo Headphone with adjustable boom microphone.
Simply plug the DH-660-USB into any USB port on a laptop or PC and enjoy rich, high-quality sound and is perfect for almost any application.
The DH-660-USB now comes with an in-line remote control to allow full adjustment of common audio functions without touching your computer.
Rounding off this feature packed product is a comfortable over-the-head design with fully adjustable boom microphone.
Dynamode DH-660-USB - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 105 dB
Microphone
Boom
Headset
Recommended Use
Computer
Headphones
Circumaural
Wired
Available Microphone
Sound Output Mode
Stereo
Sensitivity
105 dB
In-Cord Volume Control
Microphone
Boom
Sensitivity
-58 dB
Connector Type
USB ( 4 PIN USB Type A )
Headset cable - 1.9 m
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good buy
Reviewed by Pablo on 13/02/2009
I needed USB headset for my laptop and this was the cheapest I could find. However the quality is superb and it does work flawlessly both with Vista and my Ubuntu linux which makes me more than happy with this product.
5* Works well
Reviewed by Gerry on 29/01/2010
Used it yesterday for a 1 hour Skype chat through my new laptop. Windows 7 found the drivers straightaway. Good quality, quite comfortable and easy to use.
5* Fantastic!
Reviewed by Emily on 03/10/2008
Really pleased with this headset!
Inexpencive - Great audio quality and great mic!
Would highly reccomend!
5* Very good headset
Reviewed by Gordon on 08/02/2009
I had to do some homework because BT use to non-Windows users is very lacking. The spec sheet on the manufacturers website claims it works with Windows, OSX and Linux. It works like a charm on Linux. The sound is fine, build quality is fine, but my only concern in the microphone bendy steel wire; it's solidly built but it's not easy to flip it up for storage then down the exact same position next time; which means you have to do sound checks each time to make sure the volume is right. Apart from that, it's a great USB mic and headset and fantastic value for money.
4* Nice comfortable headset
Reviewed by Pizik on 03/02/2011
An excellent product considering the price. The unit I received differed slightly from the unit pictured, it appears the Mic mount has been made to a higher quality and the in-line controls are much more aesthetically pleasing than the one pictured. It did take 2 hours to get working properly in Linux Mint, however I think this is more a problem with PulseAudio as the main difficulty was getting it up and running in TeamSpeak3. Audio quality is perfect for voice, perfectly reasonable for music at moderate volumes. At higher volumes the audio suffers some distortion but at less than £10 you can hardly complain. An unusual aspect of the audio is that the balance is offset by about 13% to the left earphone. Fixed easily in OS audio config but may be an issue for the less technically minded.
2* Can't get mic to work
Reviewed by Anonymous on 01/01/2011
Despite hours of effort, I have been unable to get the microphone to work. Product came with no instructions, which didn't help. Speakers OK though.
1* Beware - not what they used to be
Reviewed by Dr John Medhurst on 27/10/2012
I purchased one of these headsets 6 months ago and it was excellent. I recently puchased a second one which was of a slightly different appearance, although still labelled Dynamode. The second one is abysmal, tinny sound, not of merchantable quality. Beware !
Scroll to top
