BT.com
Wishlist
Dynamode DH-660 PC Headset
£4.90
More than 50 in stock
£4.90
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Dynamode has established itself as one of the leading companies in its field of technology on the world markets. Dynamode has kept an edge over its competitors by creating new solutions for a changing global market, never compromising its integrity, and quality of its user friendly products.
Dynamode DH-660 - headset
Headset - wired
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 103 dB
Impedance
32 Ohm
Headset
Headphones
Wired
Available Microphone
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
Sensitivity
103 dB
Impedance
32 Ohm
Diaphragm
40 mm
Microphone
Sensitivity
-58 dB
Connector Type
Headset
Headset cable - 2.5 m
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* DH-660 is a great product
Reviewed by Nick Brandt on 08/03/2013
Brought these from BT and arrived next day, great service from BT. Cannot believe the great sound quality of these Dynamode headphones, far better than my old Trust ones. Sound is excellent, use them on my Mac and Winows 8 computer and work just fine in Skype! Recommended!!
3* Good Technology.. but flimsy
Reviewed by Antoneey on 31/07/2008
Now I've been using this headset for a good 10 months now and I have to say, it has its ups and downs. The upside is that the microphone quality is good, the sound quality is pretty good, there's even bass in them too and they're comfortable enough (providing you wear them
for 4 hours or less).. the downside to them is that they can fall apart within 10 minutes of use if you dont treat them with utter care, and the reason you should take care of them is that they will treat your ear's to a good blast of harmful noises if you don't. The wire's in the adjustable Microphone somehow get a litle mixed up with the electrics for the sound inside the headset quite easily, yeah.. I learned the hard way. For the price though, you get what you pay for. I'd buy it just for the mic in future.
Scroll to top
