BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Dynamode 42U 600x600 19" Floor Standing Data / Comms Cabinet / Rack
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Offering excellent quality coupled with value for money, this Data/Comms Enclosure range is ideal for your IT installation, no matter how big or small. Designed to the exacting standards, the Data Enclosure range offer total Networking and high valued IT device containment coupled with ease of installation and post maintenance. Used throughout both Public and Private Sector installations across the UK and Europe, they include genuine useful features such as superior hot air venting (both passive and active), heavy duty vertical uprights (both front and back) which can be fully adjusted and multiple cable entry points for correct cable placement.
Supplied with 2 Way Rooftop Fan tray, Fixed Shelf, Castors, Levelling Feet and M6 Cage Nuts.
Dimensions: w600 x d600 x h2050 (mm), weight 95kg Available ready-assembled or flat pack
Main Features:
  • Standard, UK Type Free Standing Enclosure
  • ETSI standard 19" Front and Rear vertical profiles (2.0mm thickness and fully adjustable)
  • Up to 500kg static load capacity
  • Lockable tempered glass front door with integral slotted air vents
  • Lockable steel rear door- Keys supplied as standard
  • Front and rear doors are fully reversible instantly
  • Removable side panels with latch, optional lock
  • Front, rear and top vented slots for improved air flow
  • Multiple cable entry (gland plates) in the base of the cabinet (slotted for precise cable fit)
  • Integral Electrical Earth connection
  • Adjustable Jacking Feet and Castors are supplied as standard
  • Supplied and fitted vented Shelf
  • Supplied and fitted "roof mount" Fan Tray (populated)
  • Supplied Cabinet nuts and bolt fixings for devices
  • Black Ral 9005 powdered coated finish
  • Various accessories available
Standard:
- Comply with ANS/EIA RS -310-D, IEC297-2, DIN41491 PART1, DIN41491 PART7, GB/T3047.2-92 Standard
Material:
- SPCC quality cold rolled steel
- Thickness: Mounting profile: 2mm
Degree of protection:
- IP20
Surface Finish:
- Degreasing
- Picking
- Phosphating
- Powder Coated
Scroll to top
