BT.com
Wishlist
Dynamode 19" cabinet in 450mm deep (Black)
Dynamode 19" cabinet in 450mm deep...
£50.12
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
1 in stock
£50.12
Add to wishlist
Delivery
Standard 3-5 working days
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Offering excellent quality coupled with value for money, this Wall Mountable Telecom and Data Enclosure is ideal for smaller Networking, SME and branch offices. Designed to the exacting standards, the Wall Mountable range offer a compact and secure containment system for your Rackmount active and passive devices including Switches, branch Routers, Telcom and low density cable patching. Used in both Public and Private Sector installations, this range offer the design features normally found on larger Enclosures such as front U numbering, multiple cable entry points and left/right hand Glass door location.
  • Ideal Wall Mounted Enclosures for Home, SME, Retail, Education and restrictive workspace
  • If required, can be placed on desk or on the floor
  • Standard 19" Front and Rear vertical profiles with a choice of depths
  • Passive ventilation slots with the option of Rackmount Fan Trays
  • Easy to install, can be fixed to most Wall types
  • Useful design features including front U numbering, top and bottom cable entry
  • Glass front lockable door with left/right fixing for total flexibility
  • Removable side panels
  • RAL9044 Black powder coated
  • Multiple Cable Entry Points
  • Supplied with M6 Nuts & Screws
  • Ideal for low density Network Switches, Patch Panels, CCTV and Telco systems
  • Dimensions: w550 x d450 x h320 (mm)
  • Weight: 11.3kg
Scroll to top
