BT.com
Wishlist
DYMO Rhino Pro 5200
DYMO Rhino Pro 5200
Free delivery
£99.20
DYMO Rhino Pro 5200
Free delivery
£99.20
Add to wishlist
Delivery
Standard 1-3 working days
Advanced Labeling Tool. Go for the portable, affordable label printer that builds your reputation. Show off your work with Rhino 5200 from DYMO Industrial - the label printer for datacomm, electrical, audio/visual, security, MRO, construction and broadcast professional.
DYMO Rhino 5200 - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
Portable
900 g
Media Size Class
Other
Max Media Size
Roll (1.9 cm)
Min Media Size (Custom)
6 mm
Max Media Size (Custom)
19 mm
Barcodes
Code 39, Code 128
Media Type
Heat shrink polyolefin sleeves, flexible nylon tape, permanent adhesive vinyl tape, polypropylene inserts, permanent adhesive polyester tape
Character Sizes
7 sizes
Styles & Effects
Bold, narrow, italic, underline, boxes around text
Required 6 x AA type
2 years warranty with product registration
Printer Type
Printer
Built-in Devices
Preview screen, character keyboard, cutter
Character Sizes
7 sizes
Styles & Effects
Auto Cutter
Barcodes
Code 39, Code 128
Media Handling
Media Type
Media Size Class
Other
Max Media Size
Roll (1.9 cm)
6 mm
19 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
Media Feeders
1 x manual - 1 cassette - Roll (1.9 cm)
Rugged
CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC950, UL 1950, EN 61000-3-3, EN55024, EN55022 Class B, EN 61000-6-1, FCC Part 15 B, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN50204, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 55020, CISPR 13, CISPR 20, EN55013, EN 61000-4-11, EN 61000-4-8, UL 60950-1, EN 60950-1, WEEE, EN 61000-6-3, UL 2054
AA type
Required Qty
6
900 g
Scroll to top
