BT.com
Wishlist
DYMO LetraTAG LT100H Mono Label Maker
DYMO LetraTAG LT100H Mono Label...
£16.88
4 in stock
£16.88
Add to wishlist
Delivery
Standard 3-5 working days
Label and organize anywhere in your home. Small, Sleek and super portable, the hand-held DYMO LetraTag LT00H makes it easy to organize each and every room in your home.
DYMO LetraTag LT-100H - labelmaker - monochrome - direct thermal
Printer Type
Labelmaker - direct thermal - monochrome
Portable
280 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Max Resolution (B&W)
160 dpi
Media Type
Metallic tape, plastic tape, paper tape, iron-on tape
Compatible Tapes
LetraTag tape
Character Sizes
5 sizes
Styles & Effects
Bold, normal, vertical, outline, shadow, italic, underline, boxes around text
1 line printing, 2 line printing, real time clock
Display Resolution
1 line x 13 characters / 50 x 25
Keyboard
ABCD / 45 keys
Required 4 x AA type Included Qty 0
9.5 cm x 21.5 cm x 6.5 cm
Printer Type
Printer
Built-in Devices
Preview screen, character keyboard, cutter
160 dpi
Character Sizes
5 sizes
Styles & Effects
Display Resolution
Keyboard
ABCD / 45 keys
Media Handling
Media Type
Compatible Tapes
LetraTag tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (1.2 cm)
Media Feeders
1 x manual - 1 cassette - Roll (1.2 cm)
Consumables Included
1 x tape cassette
AA type
Required Qty
4
Included
0
9.5 cm
21.5 cm
6.5 cm
280 g
Scroll to top
