BT.com
Wishlist
DYMO LabelWriter 4XL Mono Direct Thermal Label Printer
DYMO LabelWriter 4XL Mono Direct...
£204.45
£204.45
Add to wishlist
Delivery
Standard 1-3 working days
Tackle high-volume dispatch, mailing and business labeling jobs. Install a DYMO LabelWriter 4XL printer in your office or workplace and you're ready for any mailing or labeling job that comes your way. Print extra large dispatch warehouse labels, plus over 100 label styles such as file folders, name badges and more. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 4XL - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
0.78 kg
Max Media Size
Roll (11.5 cm)
Print Speed
Up to 53 labels/min
Max Resolution (B&W)
300 dpi
USB
Media Type
Thermal labels
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
2 years warranty
17.9 cm x 18.7 cm x 13.5 cm
Printer Type
Printer
Print Speed
Up to 53 labels/min
Wired
USB
300 dpi
Media Handling
Media Type
Thermal labels
Max Media Size
Roll (11.5 cm)
Media Sizes
Roll (11.5 cm)
Max Printing Width
105.7 mm
Media Feeders
1 x manual - 1 roll - Roll (11.5 cm)
1 x USB - 4 pin USB Type B
1 x USB cable
C-Tick, GS, CB, FCC, cTUVus
Software Included
Drivers & Utilities
17.9 cm
18.7 cm
13.5 cm
0.78 kg
Accessories
£15.25
DYMO LabelWrtier Standard Address Labels
Quicklinx: 2ZCB | In Stock
£8.25
DYMO 11353 Multi-use Labels
Quicklinx: 50SF | In Stock
£13.75
Scroll to top
