BT.com
Wishlist
DYMO LabelWriter 450 Mono Direct Thermal Label Printer
DYMO LabelWriter 450 Mono Direct...
£81.76
£81.76
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Thursday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Effective label printing for any budget. Professional labeling and mailing solution for your busy office. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
654 g
Max Media Size
Roll (6.2 cm)
Print Speed
Up to 51 labels/min - B/W
Max Resolution (B&W)
600 x 300 dpi
USB 2.0
Media Type
Labels, thermal paper
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
3 years warranty with product registration
12.7 cm x 18.7 cm x 13.4 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0
600 x 300 dpi
Media Handling
Media Type
Max Media Size
Roll (6.2 cm)
Media Sizes
Roll (6.2 cm)
Max Printing Width
56 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB 2.0
1 x USB cable
TUV, TUV GS, C-Tick, CB, FCC, WEEE, cTUVus
Power adapter - external
Software Included
DYMO Label Software 8
Limited warranty - 3 years
12.7 cm
18.7 cm
13.4 cm
654 g
Accessories
Ink
£15.25
DYMO LabelWrtier Standard Address Labels
Quicklinx: 2ZCB | In Stock
£8.25
DYMO 11353 Multi-use Labels
Quicklinx: 50SF | In Stock
£11.79
£7.78
Other bundles
C2G .45m USB to DB9 Serial Adapter Cable
Quicklinx: 63MC | In Stock
£14.77
C2G 3m DB9 M/F Extension Cable - Black
Quicklinx: 681W | In Stock
£5.28
C2G 5m DB9 M/F Extension Cable - Black
Quicklinx: 681X | In Stock
£7.22
C2G 7m DB9 M/F Extension Cable - Black
Quicklinx: 681Y | In Stock
£9.38
Scroll to top
